Alignment Rule
This section describes the alignment restriction rules when using BPU.
This section is prerequisite knowledge for the model deployment stage. How input data is laid out and how much memory needs to be allocated are both determined by the three properties introduced in this section: validShape, stride, and alignedByteSize. Understanding these properties is important for writing the input preparation code, and we recommend that you finish reading this section before starting application development.
Model Input Requirement
BPU does not restrict the model input size or parity. Both 416x416 inputs (e.g., YOLO) and 227x227 inputs (e.g., SqueezeNet) can be supported.
For NV12, both H & W of the input are required to be even to meet the requirement that the UV is half of the Y.
Alignment and Efficient Data
The BPU has alignment requirements for data. Valid data arrangement and aligned data arrangement are represented by validShapeand stride in hbDNNTensorProperties.
validShapeis the shape of the valid data.striderepresents the stride of each dimension ofvalidShape, describing the number of bytes required to cross each dimension of the tensor. It is important to note that models with NV12 or Y-type inputs are special. These input types just satisfy the fixed alignment constraints in the width direction, and thestridethey receive is -1. For detailed rules, please refer to the description in the Dynamic input Introduction section.
The model input and output tensors can get the correct data layout through validShape and stride.
For example, if the getted model input attribute hbDNNDataType = HB_DNN_TENSOR_TYPE_U16, validShape = [1, 3, 212, 212] and stride = [301056, 100352, 448, 2],
this indicates that the valid input size of the model is 1x3x212x212 .
stride[3] = 2indicates that each element is 16 bits in size.stride[2] = 448 = 2 * 224indicates that the dimension atindex=3is aligned according to224, therefore the stride for the dimension atindex=3is448.stride[1] = 100352 = 448 * 224indicates that the dimension atindex=2is also aligned according to224, therefore the stride for the dimension atindex=2is100352.stride[0] = 301056 = 100352 * 3indicates that ithe dimension atindex=1is aligned according to3, consistent with the valid size, therefore the stride for the dimension atindex=1is301056.
In subsequent usage scenarios, considering the alignment requirements, when alignedByteSize > 0, it is recommended to apply for memory space according to the size of alignedByteSize.
You can use the following method to determine whether the model input needs to be aligned. If the formula does not hold, you need to perform additional alignment operations on the input data.
, where, n=validShape.numDimensions.
Model Input and Output Memory Requirements
BPU has an alignment restriction on the first address of the model input and output memory, requiring the first address of the input and output memory to be 32 or 64 aligned, corresponding to different computing platforms.
J6H/P and S6P require
64alignment, and J6E/M/B require32alignment. -
The first address of the memory requested by hbUCPMalloc and hbUCPMallocCached interfaces is aligned to
64by default. -
When you request the memory and use the offset address as the input of the model, please check whether the first address after the offset meets the alignment requirements.
The alignment requirement described in this section applies to the first address of the input and output memory. Other input/output differences also exist between platforms, such as the stride alignment requirement of NV12 inputs and the minimum memory unit of non-image tensors. They are not the same quantity as first-address alignment and need to be confirmed separately. To understand the full set of input/output differences on your platform, refer to the Input/Output Handling Differences section of Platform Differences.
Common Misunderstanding
A -1 in stride does not mean that the input has no alignment requirement.
-1 means that the dimension is dynamic and needs to be calculated and filled in by you according to the actual input, rather than that the alignment handling can be skipped. NV12 and Y-type inputs fall into this case. Such inputs only require a fixed alignment constraint in the W direction, and the remaining dimensions can be derived level by level using the formula. For the detailed filling rules and a worked example, refer to the Dynamic Input Introduction section.
Where to Look Next
The model input
validShapeorstridecontains-1and you need to know how to fill in the dynamic dimensions: refer to the Dynamic Input Introduction section. -
You need to allocate memory in code and lay out input data according to
stride: refer to the Model Inference Application Development Guide section. -
You need the full set of input/output handling differences across computing platforms: refer to the Platform Differences section.
